ST IHM08M1 Shottky Diode for Encoder and Hall
Takumi Lee
I need the circuitry on the IHM08M1 board for the encoder and hall sensors two times.
I would like to ask, is there an alternative diode for the BATFILM30K, which is not built for SMD, instead built for THT.
In the data sheet "Diodes and rectifiers" I found the "BAT42 DO-35", would this be an alternative, for example, which would have the same circuit effect?
Best regards
Aaron
0 REPLIES 0
