2016-03-06 01:45 AM
(Text was missing in my 1st post. Did not work from mobile?)
Hi - does someone know whether the two LDOs on the SPV1050 will supply power even when the charging circuitry is disconnected from the battery (!BATT_CONN is high)?My application should get LDO power all the time, but it only receives IN_LV recharge voltage some of the time. Is that supported?Kind regards - #spv1050
