2024-04-05 2:09 AM
I was wondering why a 1K resistor is connected in series with the VSPI pin of the EV-VNF1048F.
The pin has a current consumption of 3mA. So does that make a drop of 3V ?
2024-04-05 4:23 AM
Well spotted, thank you for drawing our attention to this!
It t could be an error in the selection of this resistor R4. However, Ispi only has a maximum value of 3mA and is normally much lower, so that the voltage drop is also significantly smaller.
Please bear in mind that evaluation boards can also contain incorrect dimensioning.
/Peter
2024-04-05 4:23 AM
/Peter
