Program in my STSPIN32G4 is not executed while i turned controller power off and on, how to check if the code is in flash memory
rkuma.21
Cristiana SCARAMEL
Hello @rkuma.2​ ,
You can use STM32CubeProgrammer to verify content of flash memory.
Using this tool you can also force the boot from flash by selecting the BOOT_LOCK in the Option Bytes.
Let me know if these info are useful to you, if yes please "Select as Best" label.
If you feel a post has answered your question, please click "Accept as Solution"
