Output current limit for RHFL6000A
ozf
Hi All,
In this LDO the output current limit can be set by a Rshort resistor from pin 8 to V_in.
Is there any formula for the calculation of such a resistor? On the Figure 19 in the datasheet there is a plot showing Short-circuit current vs RSHORT for givien conditions (IN=COUT=1μF, VIN=6V) -- is this plot true for the entire range of the input voltages and temperatures?
ozf
Any ideas about the answer? Is there any dedicated support for aerospace products?
