2025-10-15 7:37 AM
There is no certain information about output capacitor ESR limit value for stabilization.
-Input : 5V
-Output : 4V @3A
-Desired Output Capacitors : 2x10uF 10V
Can we use Ceramic capacitors with additional series resistor? In this case what is required resistance value?
2025-10-15 8:11 AM
What ST product are you using in your case?
See How to write your question to maximize your chances to find a solution
