Need help on replacing a diode with as mosfet to realise synchronous rectification
nesrine12
I have a schematic with an ac dc converter flyback topology using the vipergan100 that deliver 100W as output power. i want to replace the secondary schottky diode with a mosfet to realise synchronous rectification but i don't know how to do this. the schematic is attached. Could any one help me?
2 REPLIES 2
AScha.3
Chief III
same here :
https://community.st.com/t5/power-management/seeking-advice-on-replacing-srk1001-synchronous-rectification/td-p/652987
Why not use the sync rect controller SRK1001 , if you want sync rect ?
here:
https://www.mouser.de/ProductDetail/STMicroelectronics/SRK1001?qs=%252B6g0mu59x7J5PdgXIuMbaQ%3D%3D
about 1 $  -- is this the problem ?
hello, the problem that i want to do simulation and the srk1001 is not available in st edsim software
