Mosfet Driver IC
shinto
Posted on February 26, 2015 at 14:14
 Output sink current and source current in Mosfet driver IC is different. Why ?
(Sink current is greater than source current)
1 REPLY 1
chattu
Posted on April 08, 2015 at 03:48
Hi Antony,
The output stage will contain a high side PMOS and a low side NMOS. As we already know that PMOS has higher resistance than NMOS, hence the sinking current will be higher than the sourcing current.
This also gives an advantage of preventing from false turn on of MOSFET due to its miller capacitance
This also reduces the dynamic switching losses when use MOSFETs in Half/Full bridge configuration
Hope this helps
Thanks & Regards
Suresh
