2021-01-19 05:00 PM
I have tested AutoDirver board(L6470) with Arduino and everything worked.
When I use Toradex Colibri EVA board (Imx 7) to control the AutoDirver board(L6470), I cannot get any response from L6470. The MISO line always low.
Can you give me clue on how to solve this issue?
Thank you
2021-01-20 07:29 AM
Recheck your wiring, reread the docs and recheck again. Test other boards. Check if logic level fit.Ither the part is broken or the error is on your side.
2021-01-20 11:14 AM
Thank you for the reply, I tested with different Colibri EVA board and L6470 board, I am sure the wiring is OK, but no luck. I will reread the docs and double check my code.
