2023-10-20 2:49 AM - last edited on 2024-02-29 7:12 AM by Peter BENSCH
I am looking for a way to send messages to a L99LDLH32 board via another program. I found the STSW-EVLDLH32GEN, but this seems to allow only to manually set select messages. What I need is to be able to determine the values programmatically and without any further human intervention, so I need an API which I can communicate with.
Does anyone know where I can find such an API alongside documentation of its use?
Edit:
Looking further through the installed files, I found the ftd2xx.h and ftd2xx.lib files. These would provide access to the board directly, if only I had the documentation for the relevant function calls.
Does anyone know, where I can find the relevant files?
Best regards,
Johannes Luber
