L99DZ100GTR Marking Information
igamoso
Dear Support,
Please help to share marking information for the part number L99DZ100GTR?
The marking info in the datasheet do not show the date code.
Peter BENSCH
The date code is as usual: three characters in the middle on the right mean YWW, i.e. last digit of the year and calendar week.
This date code should also be found on the bag label.
Does it answer your question?
/Peter
6 REPLIES 6
Peter BENSCH
/Peter
igamoso
thank you and noted on this.
Peter BENSCH
You're welcome!
If the problem is resolved, please mark this topic as answered by selecting Select as best. As you know this will help other users find that answer faster.
Thank you and regards
/Peter
igamoso
Hi Peter,
Please confirm if the full marking of the "E3" version is correct for L99DZ100GTR.
igamoso
Hi Peter,
Can you provide datasheet related to e3 version's full marking? And why is there no datasheet for e3 marking on the Internet?
Peter BENSCH
The e3 marking is in accordance with the standard IPC/JEDEC J-STD-609. It uses the JEDEC Pb-Free Category e3 logo because e3 stands for surface coating with tin (Sn).
/Peter
