2015-04-15 05:00 AM
pin 1 in the L6390 driver is LIN- (active low)
Is this mean that the pulses of this input will be inverted ?also the pin SD-2015-04-27 12:04 AM
active low means that the respective function is activated when the logic signal is low instead of high (internally inverted). e.g. forcing the SD pin low the device is shutdown. Regards Enrico
