2003-04-02 10:02 PM
2011-05-17 1:16 AM
Hi folks,
where can i look for the L6208 eval kit ? (from ST ? =) ) i tried L6208 driver in dip format on a prototype board .... i burned 2 IC so please help me to find it ! I'd like to use it for driving stepper motors in microstepping mode ....2011-05-17 1:16 AM
The Evalboard is availble through your local Distributor (Silverstar in Italy). The Order Code should be the EVAL6208. Attached you´ll find an Application Note for implementing Microstepping with the L6208 and also the scematics.
