Issue with L6599AD : Unable to generate PWM pulses from HVG (PIN15) and LVG(PIN11).
yugal_2311
Dear ST Community Member,
Currently working on development of 1.2kW EV Charger. The L6599AD (high-voltage resonant controller) IC is used for half-bridge LLC topology. We have tested the IC separately by giving different voltages at various pins of the IC as per datasheet. However, we are unbale to obtain the gate pulses. Please suggest.
0 REPLIES 0
