individual LED driver
Venish1104
Hi frds,
I've choose blue color led, that led works mention voltage & current, but my doubts is i choosed driver led driver for each LED, Which one is best ?, pls  suggest anyone....
This part no's
LED2001PH
LED2000DR
ST1CC40DR
Peter BENSCH
To be able to recommend a suitable LED Driver, we need to know a few basic parameters:
  • supply voltage range for the LED driver
  • LED forward current
  • number of LEDs to be driven simultaneously in series
  • parallel connection of LEDs planned?
You can also use the eDesignSuite for simulation and design, which can suggest the right devices for you if you select LED Lighting Design Tool, choose the type of the supply (DC/DC or AC/DC) and start the design.
/Peter
