Hi I would like to ask a question regarding the L6924U IC. The SD Pin can I leave that pin Fixed to ground as this will only truly run when power is applied on the Vin.
NHend.7
I have a Li Battery that has a NTC that is rated at 10kohm +/-5% that stops the battery from completely discharging.
0 REPLIES 0
