Hello, LD39100PU33RY & LD49100PU33RY In both cases, pin-3 of the parts has the function “Power Good�? (PG) an Open Collector pin. Is it possible to connect pin-3 PG to GND. Any issue or impact on LDO regulator operation? Thank you. Br, Predrag
POsto.1
0 REPLIES 0
