H bridge VNH7100BAS monitoring
Posted on February 15, 2018 at 09:13
I am trying to monitor the h bridge VNH7100BAS. I want to open HSA and LSB during a certain time then open LSA and LSB. But I do not succeed to do it. I use the tab 'Input A,B' and try to control the H-Bridge with but it does not work.
How can I do it ?
Thanks for your help!
#h-bridge #control #use
1 REPLY 1
leonardo miccoli
Posted on February 27, 2018 at 16:38
Hi
Marc-Aurélien ,
thanks for you
interest
on VNH7100BAS device.
If I well understand you question you want to drive the device, so you need to perform the sequence:
I want to close HSA and LSB during a certain time --> INA=PWM=1; INB=0
open LSA and LSB. --> PWM=1; INA=INB=0
For more detail on proper driving  you can refer to figure 12 on related datasheet .
thanks and Best Regards,
Leonardo
