cascade clock feed of multi STPM3X chips?
HALNA.2
Hi, I would ask a question about STPM3X, when I use multi chip of STPM3X, I can use One crystal and then cascade clock feed (Figure 27 in datasheet). Does this change the performance and the power consumption for the first master chip and slave chip?
1 REPLY 1
Peter BENSCH
No, cascading the clocks does not change either the performance or the power consumption of the connected devices.
/Peter
