QYape.1
Visitor II
August 4, 2021
Why does L7905cv have an output voltage of -10V instead of 5 when inputting -12V ?
  • August 4, 2021
  • 750 views
I' m sure GND has been connected.
s__it
Have you fitted the necessary capacitors (IN to GND and OUT to GND)? Also note that the negative regulators (79xx) have a different pinout from the positive ones (78xx). See datasheet for details.​
Peter BENSCH
Welcome, @QYape.1​, to the community!
Did you set up your circuit according to Fig. 4 of the datasheet of the L7905CV?
Are the capacitors present and located close to the L7905?
/Peter
