2017-02-18 8:51 AM
I am using the L6615 in a 50V bus current sharing application and I have the required voltage divider from each side of the high side current sense resistor to ground but I am unsure if another series resistor needs to be placed in series with the sense pins on the IC. Any guides on how to calculate these values would be appreciated. Thanks!
