ATEAVAL-IPFC01P1 abnormal operation phenomenon
Kdaeg.6
Hello
I have ATEAVAL-IPFC01P1 and I have two questions during the test of operation.
If the load is not applied, it operates normally,however, PWM1 and PWM2 signals are not output when load is applied.
As a result of checking the signals of STEVAL-IPFC01C1, the signals of RESET1, RESET2 are kept high.
Please let me know where to check.
On the data sheet, pin numbers 35, 36 and 37 are "Reserved", and signals are connected to the circuit diagram of STEVAL-IPFC01C1.
I want to know the function of this pin.
0 REPLIES 0
