softstart
jungilyong
How to create a soft start in the initial operation when generating a PWM signal with STM32
Saket_Om
Hello @jungilyong
To implement a soft start when generating a PWM signal with your STM32, you can gradually increase the PWM duty cycle from a start value to your desired value in small steps. This can be achieved by updating the timer’s compare register in a loop, with a short delay between each increment.
Saket_Om
