2024-02-12 09:57 PM - last edited on 2024-02-12 11:35 PM by Peter BENSCH
Thank you very much for your help.
My name is Ichikatai, Designe Engineering Department, NIKKI CO.,LTD.
Regarding the VNL5030JTR-E product
I believe that high melting point solder (lead 85% or more) is used in the semiconductor chip part as an exemption from RoHS.
If you have any alternative parts that are all lead-free in the event that high-melting solder is also required to be lead-free in accordance with RoHS II regulations, please contact us.
Thank you in advance for your cooperation.
2024-02-16 11:11 AM
Hi @Ichi
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
Billy
2024-02-16 11:11 AM
Hi @Ichi
Billy
