PWM pins on STM32F072CB
‎2016-10-11 11:37 PM
I am working on STM32F072CB micro controller on a custom board. I am using mbed compiler and IDE for the development. I am having an issue related to the PWM pins on mcu.I have configure PB_4(pin 40) and PB_5(pin 41) pins as PwmOut pins, but I am not able to generate PWM signals on PB_5.Can you please help me to figure out issue for the same?Thank you. #mbed- Labels:
Mbed
‎2016-10-12 4:15 AM
Hi saraf.akshat,
To let other community users helping you, try to provide more details about the hardware that you are using, if any external setup is established , and your code or part of it (Timer configuration for example).I recommend that you run the ready-to-use example ''TIM_PWMOutput'' in the library package at this path : STM32Cube_FW_F0_V1.6.0\Projects\STM32F072RB-Nucleo\Examples\TIM\TIM_PWMOutputTry to figure out what you have missed comparing with your own code (TIM2 is used in the example, replace it with TIM3)-Hannibal-- Mark as New
‎2016-10-12 5:06 AM
Hi Hannibal,
Thanks for you response. Actually I am using mbed IDE and compiler for the development purpose. I have attached a sample PWM sample code, reference board is selected as NUCLEO-F072RB. Please check that and help me. ________________ Attachments : pwm_sample.txt : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0rn&d=%2Fa%2F0X0000000bhQ%2FSRUeTagP_C2oMEBJ3TvhvZYYwDqc2zkbsyMSwpecfDE&asPdf=false- Mark as New
‎2016-10-12 5:44 AM
And can you toggle that pin manually, if you set it as a plain output?
JW- Mark as New
‎2016-10-12 6:28 AM
Hi Jan,
Yes, when i am configuring these pins as DigitalOut, these are working properly.- Mark as New
‎2016-10-12 10:18 AM
Hi saraf.akshat,
I see that you have already posted in the mbed communicty for this subject. I notify our mbed developper to investigate, and I will come back to you. -Hannibal-- Mark as New
‎2016-10-12 10:20 AM
According to the manual they are using PC7 (D9) for TIM3_CH2 and PB4 (D5) for TIM3_CH1
Now while I might expect getting the PWM out of PB5 (D4) TIM3_CH2 is possible, you'd likely have to dig back into the mbed pin definition stuff related to the board itself for that to happen.Up vote any posts that you find helpful, it shows what's working..
‎2016-10-12 10:07 PM
Hi Hannibal,
Thank you so much for your support.- Mark as New
‎2016-10-13 2:22 AM
Hi saraf.akshat,
We confirme the bug. A pull request is greated in the Github for fixing it at thishttps://github.com/ARMmbed/mbed-os/pull/3008
Meanwhile, you can use the mbed-dev source in the mbed IDE and correct it in PeripheralPins.c as follow :replace:
{PB_5, PWM_3, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF1_TIM3, 1, 0)},TIM3_CH2
by:
{PB_5, PWM_3, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF1_TIM3, 2, 0)}, TIM3_CH2
I gave you the same response on your mbed thread.
‎2016-10-13 3:14 AM
Hi Hannibal,
Thank for the support.I have gone through the mbed library source. I found the PeripheralPins.c file, but the PWM pin definition looks like this:const PinMap PinMap_PWM[] = {// {PA_1, PWM_2, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM2)}, // TIM2_CH2 {PA_1, PWM_15, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF5_TIM15)}, // TIM15_CH1N {PA_2, PWM_15, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF0_TIM15)}, // TIM15_CH1// {PA_2, PWM_2, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM2)}, // TIM2_CH3 {PA_3, PWM_15, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF0_TIM15)}, // TIM15_CH2// {PA_3, PWM_2, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM2)}, // TIM2_CH4 {PA_4, PWM_14, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF4_TIM14)}, // TIM14_CH1// {PA_6, PWM_3, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF1_TIM3)}, // TIM3_CH1 {PA_6, PWM_16, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF5_TIM16)}, // TIM16_CH1// {PA_7, PWM_3, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF1_TIM3)}, // TIM3_CH2// {PA_7, PWM_1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM1)}, // TIM1_CH1N// {PA_7, PWM_14, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF4_TIM14)}, // TIM14_CH1 {PA_7, PWM_17, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF5_TIM17)}, // TIM17_CH1 {PA_8, PWM_1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM1)}, // TIM1_CH1 {PA_9, PWM_1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM1)}, // TIM1_CH2 {PA_10, PWM_1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM1)}, // TIM1_CH3 {PA_11, PWM_1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM1)}, // TIM1_CH4 {PB_0, PWM_3, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF1_TIM3)}, // TIM3_CH3// {PB_0, PWM_1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM1)}, // TIM1_CH2N// {PB_1, PWM_14, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF0_TIM14)}, // TIM14_CH1 {PB_1, PWM_3, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF1_TIM3)}, // TIM3_CH4// {PB_1, PWM_1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM1)}, // TIM1_CH3N// {PB_3, PWM_2, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM2)}, // TIM2_CH2 {PB_4, PWM_3, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF1_TIM3)}, // TIM3_CH1 {PB_5, PWM_3, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF1_TIM3)}, // TIM3_CH2 {PB_6, PWM_16, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM16)}, // TIM16_CH1N {PB_7, PWM_17, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM17)}, // TIM17_CH1N {PB_8, PWM_16, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM16)}, // TIM16_CH1 {PB_9, PWM_17, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM17)}, // TIM17_CH1// {PB_10, PWM_2, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM2)}, // TIM2_CH3// {PB_11, PWM_2, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM2)}, // TIM2_CH4 {PB_13, PWM_1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM1)}, // TIM1_CH1N {PB_14, PWM_15, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF1_TIM15)}, // TIM15_CH1// {PB_14, PWM_1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM1)}, // TIM1_CH2N {PB_15, PWM_15, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF1_TIM15)}, // TIM15_CH2// {PB_15, PWM_1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF2_TIM1)}, // TIM1_CH3N// {PB_15, PWM_15, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF3_TIM15)}, // TIM15_CH1N {PC_6, PWM_3, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF0_TIM3)}, // TIM3_CH1 {PC_7, PWM_3, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF0_TIM3)}, // TIM3_CH2 {PC_8, PWM_3, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF0_TIM3)}, // TIM3_CH3 {PC_9, PWM_3, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF0_TIM3)}, // TIM3_CH4 {NC, NC, 0}};I think there is no need or provision to change the Timer3 channels in definition.Should i need to look in the other source.
