Others: STM32 MCUs related
Find out more about STM32 implementations with external components, discuss use cases, and discover how to use new tools and ST components.
Resolved! To read and write EEPROM IC 24c16
Is it possible to set I2C SCL and SDA pins to high and low in stm32 to read and write the EEPROM IC. If it is possible plz help me how to do that and how to generate the function to read and write the EEPROM 24c16 IC in stm32.Plz help me.Thank you
MS.11 by Associate III
  • 3648 Views
  • 10 replies
  • 1 kudos
Build TrueStudio project from command line
Dear,I am not sure If I am in the right category, but Is there any way how to build TrueStudio Project from command line? Yes the TrueStudio can be launched, but the compile command has to be send from command line.Thank you for any help.Best regard...
JJRR by Senior
  • 642 Views
  • 1 replies
  • 1 kudos
How to write EEPROM inside STM32F746G-DISCO board ?
Hi.I am developing a project using the STM32F746G-DISCO board.During development, there are cases where EEPROM needs to be used. Is the STM32F746G-DISCO usable like EEPROM by using internal flash?I tried using the STM32F746G-DISCO default sample sour...
ljeon.1 by Associate II
  • 1309 Views
  • 4 replies
How to read and write values to EEPROM IC (24C16 IC)
HI, i want to read and write values to EEPROM 24C16 IC using stm32f103 . I am able to write the value but i am not able to read the values . And how can i check whether i have written value to my eeprom ic and how to read value. can anyone help...
Lchal.1 by Associate III
  • 2224 Views
  • 6 replies
Techniques for SD Card power consumption reducing
Hello everyone,I have a complete developed board for audio recording by an attached MEMs microphone at 32KHz and using an SD CARD. Although the microphone is not supposed to be on all the time, there are some periods where it needs a continuous audio...
ALope.1 by Associate II
  • 984 Views
  • 1 replies
