8-bit DCMI Camera Reference Design?
2025-05-08 2:30 AM - last edited on 2025-05-08 2:38 AM by Andrew Neil
HI, I am MURALI SELVAM from India, I need reference design for Below given part number. I want DCMI Camera Interface 8-bit D[7:0](BT.601), PCLK, HSYNC, VSYNC. So anyone who has reference design related that kindly give me.
*****STM32F407VET6
DMA
Documentation
Ethernet
STM32F4 Series
USB
2025-05-08 7:44 AM
Video streaming over USB is feasible as the calculated throughput is within the capabilities of the USB HS interface. Here is an example.
2025-05-08 2:44 AM
https://blog.arducam.com/stm32-cameras-that-support-dcmi/
via: https://www.google.com/search?q=8-bit+DCMI+Camera+Reference+Design
and: https://www.st.com/en/microcontrollers-microprocessors/stm32f407ve.html#documentation
2025-05-08 2:56 AM - edited 2025-05-08 2:58 AM
Thanks for sharing that but I need reference schematic like tested board's schematic. If you have kindly share me and Can we do video streaming via USB?
2025-05-08 6:06 AM - edited 2025-05-08 6:21 AM
If it's not what you're looking for, why did you mark it as the solution?
To unmark it, see here.
You can't expect there to be an off-the-shelf design for every possible application just waiting for you; at some point you are going to have to do some actual design work yourself - or pay someone to do it specifically for you...
Why do you particularly want to do this on an STM32F407VET6?
PS:
If you do want an off-the-shelf design, then just go by the performance/feature requirements you need - rather than the processor it runs on.
Sounds like a Raspberry Pi would do ...
2025-05-08 6:55 AM
[Unmarked the solution]
2025-05-08 7:03 AM
Unfortunately, I was clicked Accept as solution.
2025-05-08 7:07 AM
I need reference schematics for the part number for camera interface with CVBS Signal. 8-bit parallel Signal, PClk, VSync with STM32 MCU will give video streaming via USB, is it possible?
2025-05-08 7:44 AM
