2020-12-25 01:01 AM
Why did Viper113XS removed from eDesignSuite?
Is there a problem about IC? I need to know that because I made a design and ordered the IC, if IC has some problems I need to change it.
2020-12-25 09:48 AM
Hello @Cocal.1 ,
sorry but there is a small problem with the internal eDesignSuite catalog, and temporarily VIPer113XS, only in buck topology, doesn' t appear.
A fix will be applied as soon as possible, and the design will be available again next week, but I assure that there is no issue with the IC.
Best regards,
Patrizia
2020-12-25 09:48 AM
Hello @Cocal.1 ,
Best regards,
Patrizia
2020-12-27 10:38 PM
Hello;
Thank you for your attention.
Best regards.
Can
