2005-09-11 5:33 AM
what AN describes st7 registers
2005-09-08 5:54 AM
Hello
I am totally new to st7. what AN describes st7 registers ? what should I read more ? What tool set is better: Metrowerks or Cosmic ? Thanks Oren2005-09-08 6:12 PM
registers are explained in datasheets. which device do you use ?
if you need info about some specific peripheral you can see some AN on peripherals but not abt registers. both tools are good.2005-09-11 3:02 AM
Hi
Thanks a lot. When I meant registers, I meant actually CC register description. I don't find PDF about the assembly. I found in one of the on-line courses, explanation about the CC. Oren :)2005-09-11 5:33 AM
I now found
http://www.st.com/stonline/products/literature/pm/4020.htm which is the final thing I was needed (ST7 FAMILY PROGRAMMING MANUAL) Thaks a lot Oren BTW - does anybody knows something about the overlap feature of Metrowerks ? Is it the same in Cosmic ? (I meanis it a ganeric feature of st7, or just feature of metrowerks ?) Oren
