uint8_t VL6180X_Init(void)
if(VL6180X_Read_ID() == VL6180X_DEFAULT_ID)
VL6180X_WriteByte(0x0207, 0x01);
VL6180X_WriteByte(0x0208, 0x01);
VL6180X_WriteByte(0x0096, 0x00);
VL6180X_WriteByte(0x0097, 0xfd);
VL6180X_WriteByte(0x00e3, 0x00);
VL6180X_WriteByte(0x00e4, 0x04);
VL6180X_WriteByte(0x00e5, 0x02);
VL6180X_WriteByte(0x00e6, 0x01);
VL6180X_WriteByte(0x00e7, 0x03);
VL6180X_WriteByte(0x00f5, 0x02);
VL6180X_WriteByte(0x00d9, 0x05);
VL6180X_WriteByte(0x00db, 0xce);
VL6180X_WriteByte(0x00dc, 0x03);
VL6180X_WriteByte(0x00dd, 0xf8);
VL6180X_WriteByte(0x009f, 0x00);
VL6180X_WriteByte(0x00a3, 0x3c);
VL6180X_WriteByte(0x00b7, 0x00);
VL6180X_WriteByte(0x00bb, 0x3c);
VL6180X_WriteByte(0x00b2, 0x09);
VL6180X_WriteByte(0x00ca, 0x09);
VL6180X_WriteByte(0x0198, 0x01);
VL6180X_WriteByte(0x01b0, 0x17);
VL6180X_WriteByte(0x01ad, 0x00);
VL6180X_WriteByte(0x00ff, 0x05);
VL6180X_WriteByte(0x0100, 0x05);
VL6180X_WriteByte(0x0199, 0x05);
VL6180X_WriteByte(0x01a6, 0x1b);
VL6180X_WriteByte(0x01ac, 0x3e);
VL6180X_WriteByte(0x01a7, 0x1f);
VL6180X_WriteByte(0x0030, 0x00);
// Recommended : Public registers - See data sheet for more detail
VL6180X_WriteByte(0x0011, 0x10); // Enables polling for 'New Sample ready'
// when measurement completes
VL6180X_WriteByte(0x010a, 0x30); // Set the averaging sample period
// (compromise between lower noise and
// increased execution time)
VL6180X_WriteByte(0x003f, 0x46); // Sets the light and dark gain (upper
// nibble). Dark gain should not be
// changed. !???????0x4 ?????1.0
VL6180X_WriteByte(0x0031, 0xFF); // sets the # of range measurements after
// which auto calibration of system is
// performed
VL6180X_WriteByte(0x0040, 0x63); // Set ALS integration time to 100ms
VL6180X_WriteByte(0x002e, 0x01); // perform a single temperature calibration
// of the ranging sensor
// Optional: Public registers - See data sheet for more detail
VL6180X_WriteByte(0x001b, 0x09); //???? ????
// period to 100ms ??10ms->0-10ms
VL6180X_WriteByte(0x003e, 0x31); //???? ALS??
// to 500ms
VL6180X_WriteByte(0x0014, 0x24); // Configures interrupt on 'New Sample
// Ready threshold event'
return 0;
else return 1;
uint8_t VL6180X_Read_Range(void)
uint8_t range = 0;
while(!(VL6180X_ReadByte(VL6180X_REG_RESULT_RANGE_STATUS) & 0x01));
VL6180X_WriteByte(VL6180X_REG_SYSRANGE_START,0x01); //??????
//???????????(New Sample Ready threshold event)
while(!(VL6180X_ReadByte(VL6180X_REG_RESULT_INTERRUPT_STATUS_GPIO) & 0x04));
range = VL6180X_ReadByte(VL6180X_REG_RESULT_RANGE_VAL);
VL6180X_WriteByte(VL6180X_REG_SYSTEM_INTERRUPT_CLEAR,0x07); //0111b ?????????
return range;
