2003-01-07 02:04 AM
2003-01-06 08:45 PM
I would like to use ST7F521 with a 3.3V Fpga, I have been said that the 2 additionnal port (G and H) of the 80 pins version are TTL whereas the port in the 64pin version are all in true cmos level (3.5v min for H level).
I want to have confirmation of this information. Thanks.2003-01-06 11:16 PM
The additional ports are TTL but your main concern would be that the newer revision silicon (datasheet v1.6) supports only 3.8-5.5v operating conditions.
Regards Spen2003-01-07 12:41 AM
thanks you very much but where can I find this version of the datasheet, I don't find it on this site...
2003-01-07 02:04 AM
should be accessible from this site by selecting ST72521 product from the home page
try this link too, if it helps... http://us.st.com/stonline/books/pdf/docs/7601.pdf
