2006-03-01 3:25 AM
2006-03-01 3:25 AM
Hi again.
I have some Probs finding the Reset funktion for the USB-Bulk example. I found the Reset funktion call in the usb_istr.c, but i can not find the implementation. The main problem is: I can open my USB-Device one time, and everything works fine. After closing the Pipes and the device i am trying to open it again, but now i am not able to bind the Pipes. I wonder if this problem can be solved by sending an reset-request to the device. If anyone has a better way to solve the problem, and to be able to bind the pipes several times.... :)) I'm thankful for every hint. regards re-G
