STVP error...
bleumers_j
Posted on April 24, 2003 at 10:50
STVP error...
6 REPLIES 6
bleumers_j
Posted on April 23, 2003 at 13:26
I've made an s19 file with Cosmic's IDEAST7 and when i load it in the STVP I get an error: ''Address between 0x10 and 0x2F is out of range ! - STOP loading''
What is he trying to write in this adress range. What is going wrong?
Johan
yu-jun
Posted on April 23, 2003 at 23:30
There are any errors in your *.inc file. It means HW Registers has any errors.
bleumers_j
Posted on April 24, 2003 at 05:17
IdeaST7 hasn't created any .inc file, i think this is only in case of asm files and i'm writing in C.
What are the HW registers, where can i change those?
Johan.
florent2399
Posted on April 24, 2003 at 09:28
Please check your map file. Which mcu are U using? U can download mapfiles from the ST web site.
Cheers
F
bleumers_j
Posted on April 24, 2003 at 09:49
Is the map file created with the information out of the lkf-file?
In my map file i find several variables in this adress range, but the compiler has placed them overthere (i think).
I'm using a ST7lite29 and program it with a the ST stick.
Johan
florent2399
Please can U check first this attachment? (map files for different mcus, including st7flite2)
Rgds
F
________________
Attachments :
mapfiles.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I06m&d=%2Fa%2F0X0000000bTl%2FQ8VbPUMt3xKQP99H6ZqkrBkf_JdcaQIWGS49Ymy5ZCQ&asPdf=false
