2006-06-29 02:13 AM
2011-05-17 12:30 AM
I am trying to debug STR912 using MultiICE emulator, but the MultiICE server could not find the ARM966E-S core. Who tried it well? I set the cfg file as: [Title] STR912 ARM966E-S Configuration [tap 0] ARM966E-S [Timing] Low=50 High=50 Adaptive=ON [TAPINFO] YES The board is tested ok with other tools. Regards,2011-05-17 12:30 AM
Thanks a lot. It works well. Regards,
