STR7 Dev Tools Info required
venkateswara2
Posted on March 14, 2006 at 10:17
4 REPLIES 4
venkateswara2
Posted on March 05, 2006 at 04:24
Dear Moderator,
I have worked with ST7(8 bit micos) micros quite well.
Now, I want to use the STR7 for a project. If we buy the
RVI -ICE/ME hardware for STR7 can we use that tool with
the ARM RVDS2.1 compiler/debugger etc.? or we have
to purchase the ST specific license for the compiler/debugger??
I believe the ME tool costs $200. We have a license for
ARM Relview compiler.
regards
venkateswara2
Posted on March 13, 2006 at 05:04
Hi Zouh,
Thanks for the information.
Do i have to make any changes in the RVDS2.1 tools, if i connect the STR7 with the RVI-ICE (provided by ARM)?
Thanks again.
venky
venkateswara2
Posted on March 13, 2006 at 09:15
It is the Realview ICE tool used for the ARM boards. e.g. CP & versatile boards provided by ARM. ARM supplies these boards.
regards
venkateswara2
Posted on March 14, 2006 at 06:56
hi zouh,
Thanks for the info. One more question.
I have seen ST web site. They say that the micro edition is available
with a trial version of RVDK for ST which costs $200.
I believe the trial version s/w works for 45 days. But does it also have any code size limitation. For e.g. it can compile only 2 Kbytes of code etc.?
Thank you very much.
