2006-03-22 12:01 AM
standby mode without external clock
2006-03-14 11:08 PM
I'd like to know if it is possible to exit from standby mode with the external oscillator disable, then enable oscillator and enter in RUN mode. If the answer is yes, could you tell me how to proceed (which registers to set, code example... ) Thanks.2006-03-21 06:32 PM
Thanks for this technical solution. Someone told me that the external oscillator must run before the STR's wake up because the micro needs this clock to wake up. Is it true? Does the micro use an internal clock (the RTC's 32khz for example) to proceed the wake up? Thanks.2006-03-22 12:01 AM
thanks for your help.
