ST7VD version 3.00.01 problems
keith2
Posted on January 10, 2005 at 06:25
keith2
I've been experiancing some problems with ST7VD & linker assembler.
Does anyone have any suggestion please.
Problem 1
In this example,
ramEEcopy = addr $cb
newsavzones = addr $c10
oldsavzones = addr $c11
ld {ramEEcopy + oldsavzones - newsavzones},a
I find that the ''lst'' file produces the expected code ''B7CC''
Everything seems fine, no errors reported.
but, there is a mismatch. The ''S19'' file the code is ''B74C''.!
Further investigation shows this problem with other short direct instructions as well as load.
This command is ok.
ld {ramEEcopy + {oldsavzones - newsavzones}},a
Problem 2
DATE problem
segment 'romlow'
romstart dc.b $36 ; poke neg(globalchksum+$ff) last 2 digits
romtestactive dc.b $ff ;// poke $ff
DATE
This produces S19 file with $36, $ff, ''25 Jun 2004.'' which is correct.
but,
segment 'romlow'
DATE
Produces S19 file with $ff,---------$ff x 12 then the date ''25 Jun 2004.'' 12 bytes further on than it should be.
Problem 3
Bookmark key F4 doesn't work on STV7D
