ST7lite05 external clock connection?
terryhao
Posted on November 22, 2002 at 15:46
terryhao
Posted on November 22, 2002 at 01:48
I want to use a crystal oscillator in ST7lite05. But I don't know how to connect? Could you give me a hand?
Terry Hao
terryhao@citiz.net
Posted on November 22, 2002 at 09:00
ST7Flite0 has been specifically designed to be used with the embedded internal 1% RC. Therefore crystal isn't expected to be used with this device and no dedicated pins are available.
Feel free to use the internal RC + PLLx4x8 to reach your CPU frequency: 1, 4, or 8MHz.
Pierre
maxime2399
The lite05 cannot drive a crystal directly but can accept a logic CMOS level Clock. In this configuration you can either use an external clock chip or build your own using inverters.
I found the enclosed application note from Epson very useful for my own oscillator design.
________________
Attachments :
O_D_guide.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I02K&d=%2Fa%2F0X0000000bU0%2FtuVXXrojKuDMr8.b5N0epK9VCsz8bgPNdzpgnVH6n1U&asPdf=false
