2002-11-19 4:38 AM
2002-11-14 3:15 AM
How can I clear the CMOS of the STPC Evaluation board?
2002-11-18 9:32 PM
There is a jumper somewhere on board. To be sure the clear is done correctly, I think you also have to disconnect the power supply when you play with this jumper.
Farfalla2002-11-19 3:41 AM
Farfalla;
This does not appear to work on the AtlasISABD? Is there something else I need to do?2002-11-19 4:20 AM
Stephen,
you need to follow the following steps: - power off the board - close the jumper - power on the board - check that the postcode 0D is reached - power off the board - open the jumper It should be OK now ! -- Fab
