st7lite0 PWM question?!!
‎2004-10-08 6:45 PM
‎2004-05-23 10:50 PM
I write a program like below:
CLR PADR LD A,#$0F LD PADDR,A LD A,#$FF LD PAOR,A CLR PBDR LD A,#0 ;#$7 LD PBDDR,A LD A,#0 ;#$7 LD PBOR,A LD A,#$0C LD ATRH,A LD A,#$0E0 LD ATRL,A ;PWM frequ0K LD A,#2 LD PWM0CSR,A LD A,#$10 ;fcpu= 8MHZ LD ATCSR,A BSET PWMCR,#0 ;Enable loop: LD A,#$0F LD DUTY_H,A LD DUTY_L,A LD A,DUTY_H LD DCR0H,A LD A,DUTY_L LD DCR0L,A JRA loop The problem is the PWM output frequency in the oscilliscope is not stable, it change between 9.8K and 4.9K. I don't know why. could anyone help me to explain it. Best Regards, mcuinterest- Mark as New
‎2004-05-26 3:54 AM
It is not the normal behavior. Your code seems to be ok. Pls check your cpu clock on MCO pin and internal RC oscillator settings.
‎2004-09-19 6:41 PM
I have checked clock the MCO pin and internal RC oscillator settings, there is no problem. what wrong lite0x bug?
‎2004-09-19 9:04 PM
Perhaps the problem occures because you refresh your Duty Cycle Register in a permanently active loop.
Please notice the text below of the datasheet in the chapter of the Autoreload Timer: Caution: As soon as the DCR0H is written, thecompare function is disabled and will start only
when the DCR0L value is written. If the DCR0H
write occurs just before the compare event, the
signal on the PWM output may not be set to a low
level. In this case, the DCRx register should be updated
just after an OVF event. If the DCR and ATR
values are close, then the DCRx register shouldbe
updated just before an OVF event, in order not to
miss a compare event and to have the right signal
applied on the PWM output.Hope it helps WoRo
‎2004-09-19 10:09 PM
In your code you are constantly writing to the DCR0 register, this only has to be done once for setup and then only if you need to change duty cycle.
This could cause a problem as the compare is frozen when the DCR0H is written as mentioned above. Regards sjo- Mark as New
‎2004-10-08 6:45 PM
Dear sir,
you are right, now I update the duty cyle in the overflow interrupt subroutine of auto reload timer. but the problem(PWM output wave form is not very stable) still exists in some duty cyle point(8%-12% around). I don't know why I guess it is because the DCR and ATR are very close. Just like the suggestion in the datasheet, the DCRx register shouldbe updated just before an OVF event, in order not to miss a compare event and to have the right signal applied on the PWM output. But I don't know how to update the DCR value befor OVF envent. can anyone help me!. Best Regards, mcuinterest
