2006-03-13 9:29 PM
2006-03-13 9:29 PM
I am planning to use ST72F264G2 in a new design, the design power supply is an external battery. When the battery is getting old - its voltage can reduce bellow the recommended power supply (2.7V). The device will be powered from 2.5V or lower battery voltage for a very long time, will it harm the micro? (burn it). I also use the LVD for power-up reset, is it enough? will the LVD continue to hold the device in reset in 2.5V and below?
