2004-03-29 05:37 AM
2004-03-29 12:01 AM
Problem statement:
New hardware based on ST10F168, not able to go into BSL mode. Assumptions: BSL P0L.4 pin should be held at low at the power up. No other condition required on any other pins. Regards, Sadhana.2004-03-29 02:57 AM
Can you elaborate on ''single chip mode , adapt mode and emulation Mode'' please?
I have a target board having single ST10F168..with other peripherals connected like RTC and SRAM. I want to start the processor in BSL mode so that I can download the required program for peripheral testing. At present, I'm using ST10Flasher utility and it gives me the error saying BSL Acknowledgement not received. My suspicion is my processor is not getting either proper reset requence or may be not going to BSL mode for some reason. I am in a process of finding out the cause.
