ST72324 - emulator error - undefined memory access
shlomo2
Posted on March 29, 2004 at 07:54
shlomo2
Posted on March 23, 2004 at 17:19
I'm using the DVP3 emulator board, configured to work as ST72324.
I get this ERROR which I cant resolve - can someone please help...
ERROR - stopped on undefined memory access at 0x75
kr
Posted on March 24, 2004 at 05:10
Hi Shlomo1,
>>Please check your *.h, *.c/*.asm files in which you might have assigned a register in that address(0x75) or else find out where exactly this error is appearing by using step into function so that we could findout the cause.
>>If you are using any pointers be cautious! sometimes this may give you this kind of error.
>> Please check your *.prm (Metrowerks) or the relevant files where the address mapping is done. (IMPORTANT)
>>Also, Please check the type of memory in the ''MCU configuration'' window.
With Regards
Krsel
jatin
You are trying to access the reserved area of the memory.
