2025-03-21 5:27 PM
hello, i would require a specs sheet for the following IC. i cannot find any information online. if its not visable from the picture it has a DIP20 package. Thank you
2025-03-21 6:51 PM
It's clearly a 40-pin DIP part, this dropped out of the internet with little shaking..
https://www.alldatasheet.com/datasheet-pdf/pdf/23764/STMICROELECTRONICS/ST6369.html
2025-03-21 6:51 PM
2025-03-22 12:56 AM
my bad on the Dip20 part, i forgot how to count. i searched all possible combinations and couldnt get that PDF. Thank you.
