Send text (addresing problem assembler)
brian4
Posted on April 16, 2007 at 11:09
brian4
Posted on April 16, 2007 at 09:14
Hi all
Having a bad day, simple problem but I just cant figure out the syntax
I have some text messages I am sending out on a pin, I now have the TX pin routine working.
In Assembler I want to write a routine to send each string. The strings are stored as Mess01, 02 etc.
I assume I use A,([ptr.w],X) to read the string in where X = Character position
In ROM segment I have
.Mess01
STRING ''Power On Reset''
DC.B $0D
.Mess02
STRING ''Test In Progress''
DC.B $0D
My simple question is how do I read the location (16 bit) of Mess01 or 02 etc and save that in ptr.w location
Not done much with index addressing before.
Re Brian
wolfgang2399
Posted on April 16, 2007 at 10:56
Hi Brian,
it seems not to exist a fixed rule. The code to use depends on your compiler.
The original ST asm7 works with the code (not tested!)
LD A,#Mess01.l
LD {ptr+1},A ; curly brackets!!
LD A,#Mess01.h
LD ptr,A
while my compiler needs the syntax
LD A,#LOW(Mess01)
LD ptr:1,A
LD A,#HIGH(Mess01)
LD ptr,A
WoRo
brian4
Thanks for that
Just found the .h & .l in a Link USER manual PDF and I have just typed the same as you suggested, all works ok.
One other slight funny
In my data.asm file I have defineed
ptr.w 1
However if in my data.inc file I state EXTERN ptr.w I get and error?
Error 54: Can't match Addressing mode ' ld A,([ptr.w],X)
but if I state EXTERN ptr.b I get no errors and all works.
Re Brian
