2005-01-24 9:36 PM
Searching an easy to use I2C Software solution
2005-01-24 9:36 PM
Hi all,
has anybody a solution for a S/W I2C master application with any ST7 µC? The program in the AN1045 is not really helpfull because I can't take it as it is and it seems to be a little to complicated for my application. I need a simple I2C S/W-module to connect one temperature sensor (LM75) to my lite29. A read function with a single byte address will be enough. And I would prefere a C-program. Thanks in advance WoRo
