2003-05-20 10:03 PM
2003-05-14 10:16 PM
Before flashing my ST72F521, I want to save some parameters from a DIP Switch and 2 analogic values. I want to know if it is possible to add code in sector 0 of the flash so as to save theese parameters and then flash them with the code? Has someone ever done something like this? If you could give me a sample of code it would seriously helps me. Thanks for answering. Vianney.2003-05-15 09:29 PM
I'm not sure to understand, but if you wanna do is IAP, there are some application notes available on this site with the code!
2003-05-19 02:59 AM
Yes!
Thank you, it's exactly what I was looking for!! But where can I find the files that will help me (HDFlash.c and HDFlash.h and others if needed)? Thanks for answering. Junior2003-05-20 10:00 PM
On this site, in the download part (Software Microcontrollers). Make a search on IAP!
2003-05-20 10:03 PM
Yes, I've found it.
Thank you. Junior
