2003-04-14 2:18 AM
2003-04-14 12:32 AM
I want to emulate my old programs built in AST6/LST6 on the RIDE ST6 software but it wont work... Does anybody know how to do this? I use the ST62GP DBE. Regards Bood2003-04-14 2:18 AM
You have one of two methods, either use the ''Use AST6 Syntax'' option in the options/project dialog. This will not work if you use sections though.
The best method would be to rewrite for RIDE, its not that hard to do. 1. define data.code section,eg. CODESEG SEGMENT CODE DATASEG SEGMENT DATA then use RSEG to select the current segment. 2. Use CSEG to declare your interrupt vectors/etc,eg. CSEG AT 0ffch _nmi: nop reti _res: jp reset Have a look at AN1369 from this website. Regards Spen
