adolfo
Reserved Area in ST72C334N2/N4
  • March 19, 2003
  • 829 views
Posted on March 19, 2003 at 05:40
adolfo
adolfoAuthor
Posted on March 19, 2003 at 05:24
Hello
I have a customer that is interested to know more about the reseved memory area in the ST72C334N2/N4 microcontroller .
He need this information because he is devoloping an application that require safety information .
Just to clarify I'll give you a question list that come from my customer :
1) What is written in Reserved area , because if the program counter go inside this area I need to know what can happen .
2) Is It possibile to fill this area with all FFH or 00 to avoid any kind of impredictable situation if the program counter go inside it .
3) I had experience with ST6 (ST62T32) and with this microcontroller was possible to fill the reserved area .
It is very important to know this information , otherwise the customer will choose other microcontroller from other supplier .
Please help me
Vikingo
simonharrison9
Visitor II
March 19, 2003
As far as I'm aware, the reserved area contains nothing and test code.
The ST7 can address the whole 64k memory area, the PC can contain any value from 0 - 65535.
You can try to execute anywhere !
As some of the area has nothing, it can not be loaded with a value.
There is no way to guarantee the software operation in these conditions.
You have the watchdog if it jumps into nowhere and gets stuck there.
Simon
[ This message was edited by: sjh on 12-11-2003 16:21 ]
