PSRAM Interfacing
mmgbmm
Posted on December 27, 2009 at 19:23
PSRAM Interfacing
3 REPLIES 3
mmgbmm
Posted on May 17, 2011 at 10:00
I’m trying to interface STR911FAW44X6 to a PSRAM device (MT45W4MW16BCGB). Unfortunately we’re using the LQFP128 package, which means we have to use some extra logic to get the correct interface.
The problem I have at the moment is that EMI_WRHn and EMI_WRLn are pulled low during a read cycle! Is there a register I have to set to prevent this?
We’re using Asynchronous mode only. The decode logic is:
UBn = EMI_WRHn & EMI_RDn
LBn = EMI_WRLn & EMI_RDn
WEn = EMI_WRHn & EMI_WRLn
Any help would be appreciated.
Thanks,
MM
armmcu
Hi mmgbmm
Strange behavior!!!!
Could you please confirm that the default state of both EMI_WRHn & EMI_WRLn just after Reset is high ?
Normally all EMI control signal are output high state after and during RESET.
Cheers.
tomas23
Looks to me like misconfiguration of SCU_EMI register (LFBGA/LQFP), kinda like WRh/WRl work like UB/LB.
Try to change (see the register description in RM).
